Technician ?????
Splitlog
Notices tonight on the front cylinder/right side that a piece of gasket was hanging out where cylinder goes against case right behind where pushrods go into case. Runs good and nothing leaking. Should I be worried?
Thank in advance
Splitlog
Thanks Jake. It was just hanging out. About 1/8 x 2" a little pucker factor at the beginning of the riding season. Still loving my wireplus!
Just make sure you warm up the motor before you take off cause the pressure can blow them out also :2thumbs:
Splitlog
Thanks for the input. It was hanging out and I bent it over and it snapped off. about a 2" long piece..the back side had a curve to it as if it was the entire gasket.
