Gareyh1968
I’m a new k9 owner. Sometimes when the bike is idling the tack light will flash from green to red. All the lights are on but flashing. If I give it just a bit of gas it will work properly. Any input a while it does that
Welcome from NJ,I’m a new k9 owner. Sometimes when the bike is idling the tack light will flash from green to red. All the lights are on but flashing. If I give it just a bit of gas it will work properly. Any input a while it does that
That’s an indicator - shows you visually the idle setting is too lowI’m a new k9 owner. Sometimes when the bike is idling the tack light will flash from green to red. All the lights are on but flashing. If I give it just a bit of gas it will work properly. Any input a while it does that
Thanks you!! I’m sure I’ll have more questions!!That’s an indicator - shows you visually the idle setting is too low
Thank you!If the engine runs below 900 RPM for more than five seconds, all of the tachometer LED lights will flash. Just for reference each LED in the digital tachometer represents 500 RPM.
