ChopperJeff
Just purchased a 2007 K9 and am looking at upgrading the headlight to LED. The Sunpie seems to be very popular, but is there any particular one that fits the K9? Eyeing this one:
That's the one you want. If you are using the stock bucket, the hardest part will be getting the trim ring out. If it hasn't been removed in a long time, it can be a tight sumbitch. You can get rid of the rubber seal when you put it back together. The light is a sealed unit, so that seal isn't needed. That will also create a bit more room when shoving everything back into the bucket.Just purchased a 2007 K9 and am looking at upgrading the headlight to LED. The Sunpie seems to be very popular, but is there any particular one that fits the K9? Eyeing this one:
OK, thank you! I went ahead and ordered that light. At $34 I can't go too wrong.That's the one you want. If you are using the stock bucket, the hardest part will be getting the trim ring out. If it hasn't been removed in a long time, it can be a tight sumbitch. You can get rid of the rubber seal when you put it back together. The light is a sealed unit, so that seal isn't needed. That will also create a bit more room when shoving everything back into the bucket.
I had an Adjure bucket way back when I used to own a 2005 Big Dog Chopper. The thing fell apart on the first ride after I got it installed. I sent it back to the manufacturer, and they sent it back saying nothing was wrong with it. Maybe it's just me, but I just couldn't get the thing to stay together, so I threw it away. Perhaps they've improved them since then, as I have read good things about them.Do yourself a favor and pickup an Adjure bucket, far better than stock.
Good idea, thanks! Been a while since I've messed with those light buckets, but yeah, I do remember it being a real pain getting that ring off.I also used a real strong tape applied to the ring in a few spots to get better leverage.
I'm not sure what the adjure buckets were like back then, but they are great now. I got one on the advice of Harry and Big Mike. The original bucket and trim ring immediately went in the garbage. I see their website is down currently. Maybe they went out of business. You can still get them on Amazon and ebay.I had an Adjure bucket way back when I used to own a 2005 Big Dog Chopper. The thing fell apart on the first ride after I got it installed. I sent it back to the manufacturer, and they sent it back saying nothing was wrong with it. Maybe it's just me, but I just couldn't get the thing to stay together, so I threw it away. Perhaps they've improved them since then, as I have read good things about them.
I need to pick up another one for the chopper. Dang Sunpie was floating around. Sometimes straght sometimes sideways! Took it apart and added some silicon in a few places so it wont move around. Someone musta lost the lock ring as its not in there.I'm not sure what the adjure buckets were like back then, but they are great now. I got one on the advice of Harry and Big Mike. The original bucket and trim ring immediately went in the garbage. I see their website is down currently. Maybe they went out of business. You can still get them on Amazon and ebay.
Harry, the buckets come with two rings. One is flat and the other is bent. It acts like a spring. It keeps pressure on the light so it doesn't rattle in the bucket. I couldn't get both rings in. It was too tight. I just used the bent one and it works just fine. I'm sure I still have the flat one somewhere. I'll bring it to Arkansas. All you have to do is put a couple bends in it.I need to pick up another one for the chopper. Dang Sunpie was floating around. Sometimes straght sometimes sideways! Took it apart and added some silicon in a few places so it wont move around. Someone musta lost the lock ring as its not in there.
Just remind me when it gets closer. My memory doesn't work as good as it used to.That'll work Matt, thanks!
