I first had the no crank issue and no start and only the click of the CR’s and hear nothing else no engagement of the starter. I replaced the battery replaced a starter purchased from big dog. I installed the battery and starter same problem. Just CR click nothing else. I was reading on the forums and someone had stated the possible issue could be the handlebar circuit boards. I ordered a set of circuit boards, put them in hooked up the battery and now the starter runs nonstop without even touching the button. I took it apart, put back in the old circuit board hooked up the battery same thing turning the key on and hooking up the battery without pressing any buttons I have 12 V to the solenoid and the bike continuously cranks only way to stop it is to unhook the positive to the battery. I double check the line leading. There is no shorts that I can see. Everything appears to be fine. Trying to figure out why there would be a constant 12 V to the solenoid at all times key on. Has anyone ran into this issue before? I double checked the hook ups and the ground is good to the body strap, line to solenoid is hooked and the power off the top is hooked to the power side of the battery. I’m so frustrated and stumped! I’m
