Still no running lights or tach???
Chopper117
Chopper Nutt
Hey Mob, just switched them and that was the problem. :2thumbs: I have a bad LED light. Thanks for narrowing it down for me! :cheers:
Raywood,
When I turn the key on I get no fault lights on the EHC. Now is this because I have a bad LED light or is something else going on here?? :loony: Thanks.
bdmridgeback
Low Down Chop Shop
As long as you can unplug the turn signal board and everything powers up, you should be golden replacing the board. The EHC buy passes a circuit that has a short on it. Now that it is gone, everything will power up normal.
:2thumbs::2thumbs::2thumbs::2thumbs:
Raywood,
Seems you should have had a fault lit on the rear turn signal if it was bad. :confused:
mobsta
glad i could help.i try when i can i keep it as simple as possible.i have an 04 masstiff and i have had every problem known to these dogs and many more.replace the leds and ride it like you stole bro.:cheers:
Chopper117
Chopper Nutt
Thanks for all your help fella's! I went and bought a new LED board and all of my lights work now! :2thumbs:
And thanks for that diagram Raywood that's good to have! :cheers:
bdmridgeback
Low Down Chop Shop
Almost everytime I have been at hand with a Dog problem where it wont start, There never are any fault lights on.
I think those lights are just there to look pretty in the dark when the bikes do run!!!!
