Steering stops
I thought only the RT frames had this style motor mount (straight tube) and the other frames had a curved tube!!! :confused:
Yeah well that is the frame on the ridge and k9.
Show's Ridge
And the BDM frames look like mine.
dogvet
Banned
Here's how the big dog frame does its stops...
tab on the frame
groove in the internal stops on the lower tripple
hey Gas,
It looks like your fork stop took a pretty good hit on one side.
Regarding the scoring on the fork stop, those marks look like the inner bearing race dragging like it's not rotating with the fork stem. Looks like a loose fitting bearing. You might want go a little tighter on your neck bearing preload (spec is 1-2" I'd set it at a tight 2".
Just my opinion.
hey Gas,
Just my opinion.
damn, he's good. :cheers: :cheers: :cheers: :cheers:
