Steering Head/Forks
BaldEagleJones
There are two threaded holes in the fork plates that mount to the steering head - one above and one below. I noticed I have a set screw in the lower, but nothing in the upper.
What are these for/What do these do?
Should I have a set screw in the upper?
Thats to lock the neck axle to the forks when you set the fall rate
FrankBDPS
Ray is right again. The top one keeps the axle from unscrewing and the bottom one keeps the adjusting screw from coming loose. Clean the threads up and use some blue lock tite on your new stainless steel set screws.
JeffM
I don't have those, i have 0 deg rake trees off a Duce, nice chrome & raises the front of the frame 20mm so i can get into my driveway, and it handles nice as well.
BadDawg Bill
I'm surprised since you changed the rake and trail with 0 degree offset trees.
