82ndAirborne Active Member Apr 20, 2025 #1 If the Primary (Inner and Outer) is going to be removed, is it easier to replace the starter at that time?
S Savage 1 Active Member Apr 20, 2025 #2 Generally speaking, yes. That said, we don't know what you are working on.
HMAN I just like my Freedom Supporting Member Apr 20, 2025 #3 In order to pull the inner, the starter comes out.
S Savage 1 Active Member Apr 20, 2025 #5 Removing starter Do I have to remove primary to get the starter out? 07 k9 www.bigdogbiker.com Good info in this post Has information specific to 06 k9 as well
Mr. Wright Knows some things Supporting Member Apr 20, 2025 #6 Yes, getting the start out of the hole is easier with the primary off. I haven't tried it, but I'd say you wouldn't even have to unbolt it
82ndAirborne Active Member Apr 20, 2025 #7 That's what I was thinking..it would pull out as a single unit. Appreciate it.
