Starter Pinion Gear Replacement
08 Ridgeback
Hey everyone, is there a manual or instructions on how to replace a starter pinion gear? My 08' ridgeback keeps shearing pinion gear teeth. I know the issue is deeper than the pinion gear but it needs replaced. The actual starter is only a year old. There seems to be an alignment issue between the starter pinion and the ring gear. Thanks for the help!
Mickmorris
Well Known Member
Holy smokes you seriously got a problem there! I sure hope someone here can help you out with that. Before that turns into a even bigger problem. Never seen one chewed up that bad. Good luck Bro.
