ShawnD
Hello fellas, since I've had my 08' k9 I've had an oil leak around the starter area. Just recently I had to replace my starter solenoid and I went ahead and purchased the seal kit for inner and outer primary which included the seal or seals for the starter. When I pulled the starter I discovered the starter had NO seal which was an, im guessing 3 inch diameter oring seal figured well thats where my leak is coming from so put that in put everything back together but still leaking in same area, not as bad but still leaking. I noticed in the kit I have another oring gasket that's a bit large in diameter did I miss one?
