Thorshammer96
Hey guys- I took my battery to a local HD shop and they hooked it up to a Titan 113 CI and it turned over fine. The battery is connected good and the leads are bolted in well. The (Brand new) EHC is showing good light and connection. Gotta be a bad connection from the battery to the starter somewhere, doesn't it?! Again, when I attempt to start it, the engine cranks for a 1/2 a second then quits. The turn signals start blinking. The only other thing that I can think of is one of the cable that connects to the EHC doesn't fully seat onto the EHC. I've worked on it and where it is now is as far down as it will go. The rear part of the EHC is the portion that sticks up a little bit. I can't get the rear screw to screw in. The cable won't come loose and looks good from a quick look, but... Please help me!!!! It's 68 degrees here for the first time since fall!!!!! Thanks again for all your suggestions and help! Hub
