Starter coil 2002 BD Husky
ltdagain
Long story, but I had to replace the starter coil. All electrics appear fine, bike turns over strong, but no fire to the plug. Anyone with wiring diagram for the coil? Thanks. Gotta ride this weekend!!!
X-ray Doc
If your bike is still stock, there are 3 wires coming from the cam sensor in the nose cone to the Thunder Heart ignition module under the dash, siler looking box about the size of a credit card. Then 2 wires out of the module (red,yellow) to the coil, one hooking to each side of coil. The module also has a ground wire, to the frame.
There is a red light on the module, if it is flashing when you turn over the motor cam sensor is working. If no spark still, check the coil, plug wires. You can check the coil by removing the yellow wire from coil, with ignition on, connect a jumper wire from ground
to the negitive side if coil, when you remove one side of the jumper wire you should get a spark to plug of coil is good.
If you are still having problems PM me.
