Starter Bang, I think????? NEED HELP!!
johny125
Hi Guys,
I have an 03 Husky with and S&S 107, without Compression Release. Lately, when the bike is cold, I hit the starter and it turns over fine for several revolutions and then there is an awful banging noise which I believe is from the starter. It is so obnoxious that I initially thought the noise was in the cylinders. I then let off the start button and try again and the bike either starts or turns over and bangs again. I have never had the banging noise when the bike is hot. I looked over the starter and could not see any cracks on the casing. I am looking for any suggestions as to what may be causing the banging. Should I get a new starter? Should I invest in compression releases? Any help would be appreciated.
John
ChoppaNoob
Eww bangin ?? Bad starter sometimes makes a grinding or whizzing noise when you first hit it ! Can you upload a vid catchin the sound ? Hopefully someone will chime in soon !
FrankBDPS
Mine did that kind of shit when I first bought it. If you're motor needs to turn over a few times to start It may need a tune up. I sent my starter to Wildsteedworx to be rebuilt and you must have a good battery in the bike. When the battery is week or gets run down from cranking too much the starter dosent have enough ass to turn over the motor and the compression will kick back against the starter. I thing the noise you here is the gadget inside the primary case which disengages to prevent the kick back. I am sure I will catch sit for the use of the word gadget. It's 4:47 am. The old brain cells are still snoozing.
Good luck fixing you're problem.
"You knew that was coming. Chose you're words wisely or suffer the consequences."
:oldhardlaugh::oldhardlaugh:That didn't take long, back at ya buddy:oldhardlaugh::oldhardlaugh:
francoblay1
The Spaniard
gadget
(ˈɡædʒɪt)
n
1. a small mechanical device or appliance
2. any object that is interesting for its ingenuity or novelty rather than for its practical use
[C19: perhaps from French gâchette lock catch, trigger, diminutive of gâche staple]
ˈgadgety adj
Collins English Dictionary – Complete and Unabridged © HarperCollins Publishers 1991, 1994, 1998, 2000, 2003
gadg•et
(ˈgædʒ ɪt)
n.
a usu. small mechanical or electronic contrivance or device; any ingenious article.
[1850–55; orig. uncertain]
gadg`e•teer′, n.
gadg′et•ry, n.
gadg′et•y, adj.
Random House Kernerman Webster's College Dictionary, © 2010 K Dictionaries Ltd. Copyright 2005, 1997, 1991 by Random House, Inc. All rights reserved.
gadget
- May come from French gachette, which is or has been applied to various pieces of mechanism, or from Gaget, the person who created the first so-called gadgets—miniature Statues of Liberty sold in Paris—or from a Navy term for a tool or mechanical device for which one could not recall the name.
See also related terms for mechanism.
Farlex Trivia Dictionary. © 2012 Farlex, Inc. All rights reserved.
gadget
Radar equipment (type of equipment may be indicated by a letter as listed in operation orders). May be followed by a color to indicate state of jamming. Colors will be used as follows: a. green--Clear of jamming. b. amber--Sector partially jammed. c. red--Sector completely jammed. d. blue--Completely jammed.
Dictionary of Military and Associated Terms. US Department of Defense 2005.
ThesaurusAntonymsRelated WordsSynonymsLegend:
Noun
1.
gadget - a device or control that is very useful for a particular job
appliance, contraption, contrivance, gismo, gizmo, widget, convenience
device - an instrumentality invented for a particular purpose; "the device is small enough to wear on your wrist"; "a device intended to conserve water"
gadgetry - appliances collectively; "laborsaving gadgetry"
gimbal - an appliance that allows an object (such as a ship's compass) to remain horizontal even as its support tips
injector - a contrivance for injecting (e.g., water into the boiler of a steam engine or particles into an accelerator etc.)
mod con - modern convenience; the appliances and conveniences characteristic of a modern house
Based on WordNet 3.0, Farlex clipart collection. © 2003-2012 Princeton University, Farlex Inc.
gadget
noun device, thing, appliance, machine, tool, implement, invention, instrument, novelty, apparatus, gimmick, utensil, contraption (informal), gizmo (slang, chiefly U.S. & Canad.), contrivance a handy gadget for slicing vegetables
Collins Thesaurus of the English Language – Complete and Unabridged 2nd Edition. 2002 © HarperCollins Publishers 1995, 2002
gadget
noun
A small specialized mechanical device:
concern, contraption, contrivance, gimmick, jigger, thing.
Informal: doodad, doohickey, widget.
Slang: gizmo.
The American Heritage® Roget's Thesaurus. Copyright © 2013, 2014 by Houghton Mifflin Harcourt Publishing Company. Published by Houghton Mifflin Harcourt Publishing Company. All rights reserved.
Translations
Spanish / Español
Select a language:
gadget
[ˈ>gædʒɪt] N (= little thing) → artilugio m, chisme m; (= device) → aparato m
Collins Spanish Dictionary - Complete and Unabridged 8th Edition 2005 © William Collins Sons & Co. Ltd. 1971, 1988 © HarperCollins Publishers 1992, 1993, 1996, 1997, 2000, 2003, 2005
gadget
(ˈgӕdʒit) noun a usually small tool, machine etc. a useful gadget for loosening bottle lids.aparato ; dispositivo ; artilugio
chubs
gadget
(ˈɡædʒɪt)
n
ˈgadgety adj
gadg•et
(ˈgædʒ ɪt)
n.
gadg`e•teer′, n.
gadg′et•ry, n.
gadg′et•y, adj.
gadget
gadget
Noun
1.
gadget
gadget
noun
Slang: gizmo.
Translations
Spanish / Español
Select a language:
gadget
gadget
gadget
(ˈɡædʒɪt)
n
ˈgadgety adj
gadg•et
(ˈgædʒ ɪt)
n.
gadg`e•teer′, n.
gadg′et•ry, n.
gadg′et•y, adj.
gadget
gadget
Noun
1.
gadget
gadget
noun
Slang: gizmo.
Translations
Spanish / Español
Select a language:
gadget
gadget
Holy shit! I didn't know there was that many definitions for that one word. I thought it just meant a little whatchamacallit!
johny125
Sounds about right. Thanks for the advise. John
