starter and wire plus question
bobbyg
Hello everyone , I have a couple of issues I could use help with on 2007 pit-bull . I had a wire plus kit put on and now the bike seems to over rev when I throttle it hard almost like something is slipping, belt and clutch seem fine. Normal cruising no problem. Also put a new starter on last year everything worked fine. Just got the bike out with a known good battery and lights flicker and clicks a few times when trying to start. Not sure maybe bad connection somewhere . Any ideas would be appreciated thank
Brew
Welcome from Washington State, hope you enjoy the site... :cheers:
Sounds like your clutch is slipping when it's reving and not moving with the gas on. Is this happening when you have it in a higher gear and gas it? If so then thats what it would be. Some causes are clutch out of adjustment or your clutch hub nut is loose to a cracked clutch carrier assy..
The battery issue, are you sure its a good battery? Have you had the battery load checked? You might want to do that to ensure it's good! Whats the battery brand? Get back with us and we'll take it further.
By the way please go to the introduction thread and create an into if you please...:D :2thumbs:
