I have the OEM air cleaner that would have came on the K9 in 06, The previous owner bought the spike ( I assume from Big Dog) as i received it in one of the boxes of parts i got with the motorcycle when i bought it a couple weeks ago.Welcome from Kansas. What do you need assistance with? Which A/C do you have now and what A/C are you adding? There are several "spike" A/C's. Most are straight forward installs.
Exactly, I have the dog eared piece behind the intake elbow that goes on the carb, So i assume i simply install that piece with gaskets on both sides and then bolt the intake to it? There was another piece in the box sort of like a spacer but i believe that came from something else and did not belong.So you have this;View attachment 119446
But want this;
Compare the pics and your parts stash.
Yup. Install is fairly simple. You may be able to find gaskets or you may have to cut some to fit?Exactly, I have the dog eared piece behind the intake elbow that goes on the carb, So i assume i simply install that piece with gaskets on both sides and then bolt the intake to it? There was another piece in the box sort of like a spacer but i believe that came from something else and did not belong.
Yep. It happens when they get hot & old. What ignition module do you have on your awesome BigDog?Good Morning, Well i installed the starter and it appeared that everything was fine but as it turns out i now have another issue. The bike will start intermittently. Which i believe is now the ignition module it is sending the signal to the ignition coil hit and miss, Has anyone ever dealt with this?
