Spike Air Cleaner Install
NEOHIOK9
I have a 2006 K9 and want o change out the intake to the Spike Air Intake, I have the parts ( I Think ) that came with the K9 when i bought it, Does anyone have the installation instructions for this? Any help will be much appreciated.
Welcome from Kansas. What do you need assistance with? Which A/C do you have now and what A/C are you adding? There are several "spike" A/C's. Most are straight forward installs.
NEOHIOK9
I have the OEM air cleaner that would have came on the K9 in 06, The previous owner bought the spike ( I assume from Big Dog) as i received it in one of the boxes of parts i got with the motorcycle when i bought it a couple weeks ago.
Exactly, I have the dog eared piece behind the intake elbow that goes on the carb, So i assume i simply install that piece with gaskets on both sides and then bolt the intake to it? There was another piece in the box sort of like a spacer but i believe that came from something else and did not belong.
Yup. Install is fairly simple. You may be able to find gaskets or you may have to cut some to fit?
NEOHIOK9
HMAN and MR.Wright, Thank you both for the help on this. I now have two new friends in the Big Dog community. I am currently waiting on a starter that should be in tomorrow. ( Another issue i inherited with the K9) Once i get it complete i will post some pics) I appreciate you both. Stay Safe.
NEOHIOK9
HMAN and Mr, Wright, As promised here she is Spike installed, I am still waiting on my starter which should be in tomorrow but she is getting closer to being back on the road. Thanks again for the help on this it turns out i had all the correct pieces i just had to dig in the boxes i got with the bike. Thanks Again. Stay Safe
NEOHIOK9
Good Morning, Well i installed the starter and it appeared that everything was fine but as it turns out i now have another issue. The bike will start intermittently. Which i believe is now the ignition module it is sending the signal to the ignition coil hit and miss, Has anyone ever dealt with this?
Mickmorris
Well Known Member
Yep. It happens when they get hot & old. What ignition module do you have on your awesome BigDog?
Just throwing this out there for ya, ya may have a tuning issue with the spike. Keep the stock cause you may wanna put it back on. Ask me how I know.
NEOHIOK9
HMAN, If the new IM does not fix this issue that may be where i go next, I see i can buy the two harness's that go from the IM to the Ignition Coil from Wild Steed Worx in California, And since after i install the new IM, I will have changed the IM, Ignition Coil, Battery, Starter, Crank Position Sensor and New plug wires i am starting to run out of things to change, But the motorcycle runs fantastic the few test rides i have been on since i bought it a few weeks ago. But with that said, She will live again because i will not give up until i push the start but and she jumps to life EVERY TIME, Thanks for the info.
