speedometer codes
narow37
Angry Southern White Man
it may need to be calibrated. the service manual, at least my 07' manual has the instructions. basically you put the speedo in calibrate mode and ride the bike for a measured mile(I think) and then do something else. this sets the speedo for the correct speed.
beano
speed o sensor location
i have an 02 pitbull and no owners manual where is the speedo sensor located? mine isnt working
on top the transmission just behind the trap door, oval shaped aluminum cover with a wire coming out of it.
beano
by the way i cant do anything as far as calibrate goes the button on my speed o does nothing when i push it
thanks ill look for that and clean it with something i guess
DO U THINK I NEED A NEW SPEED O SENSOR?
HELLO!!!!!!!!
Did you clean the sensor yet????
Have you ordered a Service Manual? It has the calibration sequence in it.
Can't tell you if you need a new speedo sensor if you haven't first cleaned it and tested it!
HELLO!!!!
:flag:
Not to dog you out but clean your sensor then tell us if it corrected your problem then we can go from there.
Good luck,
Ray
beano
SPEED O BUTTON STILL DOESNT WORK.SORRY RAY IM GOING TO MYRTLE THIS WEEKEND AND I GUESS IM A LITTLE IMPATIENT
beano
I FOLLOWED CALIBRATION INSTRUCTIONS BUT WHEN I PREES BUTTON AND SWITCH ON PULSE SHOWS UP THEN I RELEASE AND THEN THE TWO OTHER WORDS SHOW UP.NO NUMBERS AT ALL
beano
I THINK MY ACTUAL BUTTON WASNT WORKING.I PUSHED SO HARD I THOUGHT I WAS GONNA BREAK GLASS AND I HEARD A CLICK.NOW EVERTHING IS WORKING CORRECTLY,FOR NOW AT LEAST.
T.Byrd
Will someone do a how to on cal. a speedo, I don't have a service manual
eather.Mine quiet working when you turn it on it cals. to 60m.ph. and reads out a #, then goes back to zero after that the tack works but the speedo does not.
