Konstantine
Need to change spark plug wires on my 2009 Big Dog Coyote. To remove coil cover shop manual says that I need to remove engine mount screw that has red (2760) loctite as well as ignition coil mounting plate screws that also have red (2760) loctite on it. Normally heat would need to be applied to remove a bolt with red loctite, but I can not apply the heat because it will melt my wires. Any suggestions on how to remove these bolts/screws?
