Spark plug Question ??
BadBrad
2005 Pitbull
Brad,
Is Rocky still complaining about your "little cable falling out"? :eek:
:roll::roll::roll::roll::roll::roll:
:D:cheers:
Hey,
Don't be hatin' just because you leave yourself wide open for that. I would expect the same if I were ever to be so stupid. Probably won't ever happen, but who knows? Rocky is home recouperating from an early "wake up" call. :job: Don't make me wake her again to set you str8. :whoop:
Hey,
No hatin', but I do think that somebody needs to restrict all of Brads postings to the "Help Wanted" section ONLY! :loony: :crazy: :cry:
:roll::roll::roll::roll::roll::roll::roll:
:D:cheers:
"Help Wanted" just a "little" :job:....:D:roll:
It's either that or some John Bobit cosmetic surgery! :2thumbs:
:D:cheers:
BadBrad
2005 Pitbull
:D:cheers:
Now that's probably something Rocky would agree with. :loony:
This thread was over, right? :rolleyes:
I think it ended with "any brand of plug that is firing is a good plug", or something like that. :job:
I'll chime in and make mention of to snug the gap to .035" when pushing the ccp up.
While the spark kernel may not be bigger, it will be more intense, and when the chamber turbulence is up, with more ccp, they respond to the tighter gap.:flag:
Scott
Stinky7-11
remember the spark plug just ignites the fuel mixture, if your bike is set properly the plug will not make much differences. platinum's, and iridium are a little harder to foul. I still use the champions and changes around every 10000 miles but they still look good, ( but I do check regularly on condition. )
What he said!!:up::up::up:
TheCleaner
Well I did notice a huge difference when starting her up cold...fired right up and seemed to idle/run much smoother! My champs never fired up like that on a 30 degree day...and I'm pretty good about keeping my bike dialed in. I gonna throw some in my jeep next!
Be carefull with the NGK plugs the caps spin on... with the high vibe vtwin motors they can spin loose.
On the BDMs its a simple matter of less fire, more resistance...
On HDs it can throw engine codes.
