Slipping clutch
Jwooky
I just waned to share my experience with my clutch slipping.
Been struggling with this issue for a few weeks.
Long story short, thanks to help from Anderew (Bigdogtech) and also James from Baker, we were able to determine the clutch hub nut was loose.
I had checked it initially and it appeared to be tight. I was about to replace the clutch and Andrew convinced me to remove it any way and reseat it.
It appears it had been previously locktighted, so it backed off and reseated.
Once it broke it loose it was obvious it was not tight to the hub.
I cleaned the nut/shaft with lacquer thinner and then locktighted and torqued to 150ftlb
Did a 200 mile ride and no slipping!!:up:
mirage814
Mine just started to slip too. Not too mechanical but wasn't to strart doing some work. Have any pics to show location etc?
