No H2O
I used to only use the gauge that came with the air tool inflater and attached to a pancake air compressor.
Then I got the analog one on the right and it would show a higher PSI than the pancake compressor so thinking that it took a greater "force" of air to fight the friction on the rod that pops out of the pancake compressor gauge, I started going by the manual gauge.
Since I moved into an apartment and can no longer run a pancake compressor I got this portable slime compressor with built in gauge that runs off the car cigarette lighter port.
At first the gauges were all roughly reading the same.
Then the small slime digital gauge started to read 8-10 psi low.
Soon after the manual gauge started to read 8-10 psi low.
So at this point the gauge on the slime compressor reads higher than both the analog and small slime digital gauges.
If these were small differences like 1-2 lbs I wouldn't care but the slime compressor is reading 41psi while the other two gauges are showing 33psi for the back tire, that's almost 10 psi difference.
Is there an accurate gauge out there?
