Screw needed for EHC Plug!
1goodsinner
I've noticed that after riding for even a fairly short ride that the vibration has the tendency to loosen the 4 screws holding down the 2 large black electrical plugs on the EHC.I tighten them down when I return home after the ride,but 2 nights ago I did not heed my own warning when tightening them and snapped one of them off.Where do I get a replacement screw?I have gotten the broken end out ok.
pknowles
RETIRED
Check out your local FASTENAL dealer, they can get just about anything you need. If that don't work I may still have the old ends that I removed while installing the wire+. Let me know.
BigDogBro1
Made in the USA
If I recall correctly, I think a #4-40 machine screw at the same length will work. Get one at any GOOD hardware store.
chacha
Chaff Your EHC!!
Or zip tie them to the unit -- keeps them tight and no worries about the crappy screws.
1goodsinner
Thanks guys for the responses!I'll try to get the screws,but will also try the "zip-tie" deal.I didn't even think about being able to get one around the EHC. Duh!
PurpleDog
Above are good suggestions; you might try your local computer parts/telecom warehouse as well, should be standard machine thread connector screws used throughout the industry. Think about the old RS232 (and the like) connectors - should be the same thing as far as the screw itself. Can buy 'em in bulk, I just threw away hundreds of them.
Nukeranger
Nukeranger
Find someone with RS-232 cables. Geeks save these cables. If the screw fits, Locktite it. Even if you tie wrap it, it will still back out due to vibration and get lost again.
Mr.D
Don't forget the Dielectric Grease on the plugs !!!!!!!!!!!
send a self adressed stamped envelope to Addictive Behavior Choppers.
365 west 9000 south. Sandy,Utah.84070
I'll be happy to send you a couple if it helps
1goodsinner
My gf is trying to locate them today,if unsuccessful Mr. D,then I will drop you a SASE for a couple screws.Yes,I had thought about using the spray cleaner on the contacts and then dielectric grease.Thanks for additional help.Can't have too much of that.
