S&S G carb
RLA671
Anyone had a problem like this. S&S 107 3000 miles with a G carb. Sat for 1-2 years stale gas, drained tank & carb-cleaned carb ran ok but stalled when moving or tuning at low speed. Set float & carb mix-accel pump & idle but when motor runs for 1-2 minutes fuel drizzles from the brass rod on the ac side of carb throat, new oring-float adjust same thing. Any thoughts??? Thanks:loony:
spadesluck
You sure the fuel line to the carb is good? Sat that long stuff could still be clogging it up, floating debris and what not. did you take that carb all the way apart and clean it from top to bottom? Fuel sitting that long tears stuff up bad. Sounds to be like there is still stuff that is clogged up somewhere.
