S&S 117" to 124" Pro's and Con's
reddog06
hi if u want to pop wheelies ,call baker trans an buy a 30 tooth alluminum race pully that weights 2 pounds ! u have a stock steel 34 tooth that ways close to 5 pounds thats comes stock on ur bike now,u do have to do some modifications to make it fit, ( lathe work ) u have to change out the belt to center the tire in the fender! u pull out of the hole like a rabbit with that lower ratio an lighter weight pulley on the trans !!! well worth the work ! jim
armad
Don't mean to highjack your thread, but you say you don't use 6th gear much. I have only had my bike a week and I noticed you have to cruise about 70-80 in 6th before it quits lugging the motor S I don't use 6th much either. It seems to me the bike is geared way to high in the top two or three gears. What is involved with changing the gearing? I am assuming you are changing the gearing on the motor. Do you need to get a different primary chain. How do you determine what size gear to use?
