BroadBand
Since late 60's
From an old post:
Bigdog had a problem with early Daytech frames. The pivot pin doesn't have a big enough spacer where it goes into the frame.
Because of that, the pin is getting bent causing everything the get out of whack. Started out with a whinning noise on decel from the primary.
Noticed a rub mark on the rear tire. The dealer discovered that the rear wheel was so far out of alignment that the tire was rubbing against the swingarm.
The alignment problem was causing the belt squeel. The whole problem also caused the rear shocks to blow out.
