Running great then... not so much!
BigDogBro1
Made in the USA
Great to here the good news that you found the problem. It's a great feeling to get it back running! Enjoy the ride! Glad we could help keep you troubleshooting the problem untill you found it.
Pretty sure I still have my original EHC so Im gonna leave the resistor in for now. My bike is running so good right now, I dont want to touch a thing :)
The resistor was a quick fix to the original EHC's used in the new models when they came out in 05. If you still have the original EHC then DON'T remove it! Once you get the updated EHC you can pull that out. They didn't do it when mine was replaced (mechanic shattered some lights) and I email BDM about it and they said I could pull it but didn't need to. I pulled it out anyway.
With the original 05 EHC's there was a chance that a spike or to much voltage (or something like that) could cause your EHC to melt down. This was the fix till they updated the EHC's. I know because mine melted down on the side of the freeway back in 05.
KickStand
Thanks for in info Raywood. Ill definitely keep that resistor in place, unless my EHC needs to be replaced. If it does need to be replaced I will go the Wires Plus route instead of another EHC.
