xxcarpxx
I did rev it up while checking it, and did see and increase of voltage. But I'm not sure I ever saw anything up to 40 Volts... Low 30s from what I can remember..Although I wasn't heavy into the throttle, if that matters..did you happen to increase the RPM when you were checking the stator plug? the voltage should increase with RPM up to about 40 volts at higher revs.
