Rintintin
Happy Friday. Who is ready for spring already?
This past weekend, I was doing some winter preventative maintenance and upgrades on my 2006 Mastiff when I hit a snag...
I took my right hand control apart to 1) replace the original throttle grip with a new one from HDM and 2) rebuild the front brake master cylinder. I got the throttle grip replaced just fine; but I could not figure out how to remove the c-clip from inside the confines of the front control body. My c-clip pliers would not reach.
I gave up on the brake master cylinder rebuild for now and put the assembly back together. When I was tightening the bolt (part #19 in the diagram below) into the throttle cable cover cap ( #14 in the diagram below) when the head of the bold sheared off after being screwed all the way in and on final tighten. The head and about 2 threads is all that broke off.
Everything works fine, but I'm not sure where that leaves me. I would love to hear some of your experience and ideas:
1) Does the throttle cable cover cap serve a functional purpose or is it mostly for looks?
2) After the bolt broke, I tried to slide the throttle cable cover cap out and it does not seem to be coming out, so is it ok to leave it as is for now?
3) When I actually have to rebuild the front brake master cylinder at some point, how can I get the remainder of bolt 19 and the throttle cable cover cap out to take the assembly apart?
Thanks.
Dave
Thanks.
Dave
