reveria primo vs bandit clutch
Rufus1
looking for opinions on keeping the reveria primo clutch which i believe is stock, and just replacing the clutch pack or upgrading to the bandit clutch. i have the 2004 mastiff with the 117 motor which is being rebuilt. it has the S&S dual a/c, martin bros., madusa exhaust pipes, xxx carb. with in the rebuild I'm adding the 600 cam and .640 valve springs, port and polished heads, zero decking the head and cylinders,limiter tappets. not sure what hp will end up at but i thought i read on here someone only getting about 20hp extra. if that the case should running the stock clutch be a concern.
Rivera Primo isn't really a "Stock" clutch.
The clutch in your bike now is generally sold as an aftermarket performance clutch.
Its more than satisfactory for your motor size and HP.
Rufus1
thanks Curtis just trying to make any upgrades necessary since I have it tore down. I'll just ordering the clutch pack kit from you.
