I pulled my starter and had to pull my primary cover. Not sure if there is a better way but these are the steps i took:
1. drain primary oil
2. Remove outer primary cover
3. remove jackshaft bolt (there is a long bolt in the center that runs to the start I believe)
4. Removed pipes
5. there are two allen head bolts that hold the starter in place, remove those two and pull
