Posted in vintage also. Needing some help if anyone has any ideas. I'm looking for a replacement coil suggestion as I'm getting 8k ohms on the secondary and spark is pretty meager. Primary is fine at 3.4 ohm. Replaced plug wires initially as had one bad wire also. Any idea what was original to this bike as it's a tight fit and my coil doesn't have any marking. It's a 3ohm dual fire cylindrical about 2 inches long and 1 1/2 " dia. if you have any suggestions its paired with a Dyna ignition 2000i I believe?
Needing 3 ohm primary and 12k ohm secondary that is small enough to fit under factory cover. Thanks - Paul
