Replaced ICM...
drbalazo
I replaced my Thunder Heart ignition control module with a new one after having some issues with the old one and now the cam sensor went bad. I am replacing it tomorrow and hope my starting issues get resolved. Having replaced my parts with OEM parts, do do you think I will have the same issues in the near future?
I know I should of gotten a wire plus, but didn't because the wire plus was out of stock and didn't want to wait.
Who has replaced these parts with OEM parts and have had issues again?
DRBarnhart
Insert title here...
The WirePlus has nothing to do with your ignition control module or cam sensor except to supply power to it. :D
Dennis
PS Are you sure the cam sensor wasn't the problem in the first place? :confused:
drbalazo
I thought the wire plus made it so that my ICM wouldn't be a problem no more. Maybe I was mis informed. Before i replaced the ICM,i checked the cam sensor and it was fine, which led me to test the ICM and found out it was bad. This time, the cam sensor really is bad.
DRBarnhart
The WirePlus replaces the EHC (electronic harness controller) not the ICM (ignition control module) so if you don't have EHC problems save your money! :cheers:
Dennis
drbalazo
Replaced the cam sensor and has been running fine. Im thinking of getting the wire plus just in case. Thanks all for your help.
