RVH
I thinking the front lifters are sticking. When I first lifted the tubes and rotated the rod to the low point on the lobe, the front intake rod was loose(like 1/8" play). I turned the motor over a few times to the low point again and both front rods were loose. Kept checking and now they're tight. Never could get the rear rods to be more than twistable with my fingers.............Thats the way it was running, good for a few minutes then would skip with a tapping noise at the front cylinder. If anyone thinks it might be something other than sticking lifters, please chime in. In the meantime, can I remove the lifters by shortening the pushrods and/or removing the tappet blocks? ........
