Two pinch bolts on right fork, remove the axle bolt on left side and then thread it in a few turns and tap on it with a rubber mallet. Axle should slide right out.
Thanks Mossberg, I found the set screw on the left side cover. removed the cover removed the lock nut and the axel tapped right out. Time for some new rubber, assembly then it's summer time! Thanks
