"RECALLS" 2004 **UPDATED Jan. 10, '10**
"DAYTEC CHOPPER" Year : 2004 **RECALLS**
deleted
Request For BDM/BDB Administrative Assistance!
"CHOPPER - DT" Year : 2004 **RECALLS**
deleted
humpty2032
funny, i contacted a dealer and the only recall they said was on the 04 ridgeback was the kickstand.... bastartds.
they also said that they cant tell by the vin if the recall was done or not. what kinda crap is that.
Big Mike
Report Date: January 10, 2010 at 11:38 AM
Search Type: VEHICLE
Make: BIGDOG
Model: PITBULL
Model Year: 2004
Results : 4 | All records displayed
Make: BIGDOG Model: PITBULL
Model Year: 2004
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: MAR 22, 2004
NHTSA CAMPAIGN ID Number: 04V137000
N/A
NHTSA Action Number: N/A
Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:MASTER CYLINDER
Potential Number of Units Affected: 1906
Summary:
ON CERTAIN MOTORCYCLES, THE PISTON IN THE REAR MASTER CYLINDER MAY HAVE BEEN IMPROPERLY SIZED, WHICH COULD CAUSE THE REAR BRAKES TO DRAG OR LOCKUP.
Consequence:
THIS COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL REMOVE THE PISTON FROM THE REAR MASTER CYLINDER AND REPLACE IT WITH A NEW PISTON. OWNER NOTIFICATION BEGAN ON APRIL 12, 2004. OWNERS SHOULD CONTACT BIG DOG AT 1-316-267-9121.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Check to Request Research. Submit below.
Model Year: 2004
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: APR 05, 2004
NHTSA CAMPAIGN ID Number: 04V164000
N/A
Component: STEERING:WHEEL AND HANDLE BAR
Potential Number of Units Affected: 2098
Summary:
ON CERTAIN MOTORCYCLES, A SCREW MAY BECOME LOOSE IN THE HANDLEBAR CONTROL DUE TO THE LACK OF A LOCK WASHER AND LOCTITE.
Consequence:
THIS COULD CAUSE THE THROTTLE OR FRONT BRAKE CONTROL TO BIND, WHICH COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSTALL A LOCK WASHER AND LOCTITE. OWNER NOTIFICATION BEGAN ON APRIL 12, 2004. OWNERS SHOULD CONTACT BIG DOG AT 1-316-219-7006.
Notes:
Model Year: 2004
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: OCT 27, 2004
NHTSA CAMPAIGN ID Number: 04V523000
N/A
Component: STRUCTURE:MOTORCYCLE KICKSTAND/CENTER STAND
Potential Number of Units Affected: 4457
Summary:
ON CERTAIN MOTORCYCLES, THE KICKSTAND SPRING ATTACHING STUD MAY BREAK OFF ALLOWING THE KICKSTAND TO DEPLOY INTO THE EXTENDED POSITION.
Consequence:
IF THE KICKSTAND DEPLOYS, IT COULD CAUSE A CRASH WITHOUT PRIOR WARNING.
Remedy:
DEALERS WILL INSPECT AND INSTALL A NEW KICKSTAND UNIT. THE RECALL BEGAN ON DECEMBER 20, 2004. OWNERS SHOULD CONTACT BIG DOG AT 316-267-9121.
Notes:
Model Year: 2004
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: JAN 20, 2006
NHTSA CAMPAIGN ID Number: 06V019000
N/A
Potential Number of Units Affected: 9726
Summary:
ON CERTAIN MOTORCYCLES, THE KICKSTAND SPRING MAY STRETCH AND DETACH FROM THE MOUNTING BRACKET OR THE KICKSTAND.
Consequence:
THIS WILL ALLOW THE KICKSTAND TO DEPLOY INTO THE EXTENDED POSITION AND CAUSE A CRASH.
Remedy:
DEALERS WILL INSTALL A NEW KICKSTAND SPRING FREE OF CHARGE. THE RECALL BEGAN ON FEBRUARY 17, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
Notes:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Dead,
This is very helpfull. Appreciate the info. I've seen the recall posts previously, but just started noticing my rear caliper dragging. I will call them tomorrow & see if my Pit is included.
I've been tyring to research my rear rotor. It's scored pretty good now & I think the grooving might be too deep to resurface. I think it must have been dragging periodically before I bought it. All I can find is a part #, but no manufacturers name.
Anyway, very good info. dude:cheers:
Ray
It is just crap like you said, they know they have problems, issues, and a bunch of crappy EHC,s , cam sensors etc. They told me there was no recall on mine either, as I am waiting to replace the EHC with the wire plus AWE......!!!! because it won't start, and unlike the Mc Donalds commercials mine only pushes well on a down hill grade and the kick starter must have been optional.. Awaits the wire plus system from Jake, my scooter collecting dust in the garage,, but that is ok,, I will fix it better. Too hot anyway ,,,
Ray :up:
seatmaker
Ray :up:
Im waiting for a Wire Plus also. What does the Cam sensor do when it goes bad and what is a better replacement?
