Recall info deleted?
mittens
I am hopefully buying a 2004 Chopper tomorrow.
after reading a lot on here, it seams this year could have or had a frame problem / recall. Its a black frame so its going to be hard to see a crack anyway.
Any Ideas where to get the info on the recalls and weather or not it was done? or if it was even in the right time frame?
The threads have all the information deleted.
By decoding the VIN
Its a 2004 Big Dog Chopper, with a Rolling Thunder Frame (RT), 107 Cube motor, made at plant W, and it was number 752 in production that year so I assume that's pretty late in the year? But I dont know the production numbers? And have googled and searched and cant seam to find that info.
So any idea how to find out if it is something to be a problem or what.
mittens
When I do a search it just shows electrical. But I know mine is a N frame being a rolling thunder. But is it all RTs or just in a range of vins
grizfish
My RT frame was built early in the 2003 model year (ser. no. 000075). Big Dog sent the recall notice on Jan. 15, 2004. The recall process was completed in Wichita, April 2004.
It was called:
Safety Recall Notice; Campaign No. 03V-535; Chopper Frame Remedy
They added a reinforcement piece between the upper engine mount and the front frame gusset. It fits around the front gas tank mount. It's a similar size tubing as the upper engine mount and front frame gusset and welded to them.
You should be able to identify it by looking from the side of the front gas tank mount. They did an excellent job of welding and painting, so you can't tell it was an added piece, except that it stops at the front of the upper engine mount.
The recall paperwork only lists my ser. no., so I don't know which other frames were included.
N8KAM
Report Receipt Date: JAN 25, 2006
NHTSA Campaign Number: 06V019000
Component(s): STRUCTURE
9 Associated Documents
Manufacturer: BIG DOG MOTORCYCLES, LLC
SUMMARY:
ON CERTAIN MOTORCYCLES, THE KICKSTAND SPRING MAY STRETCH AND DETACH FROM THE MOUNTING BRACKET OR THE KICKSTAND.
CONSEQUENCE:
THIS WILL ALLOW THE KICKSTAND TO DEPLOY INTO THE EXTENDED POSITION AND CAUSE A CRASH.
REMEDY:
DEALERS WILL INSTALL A NEW KICKSTAND SPRING FREE OF CHARGE. THE RECALL BEGAN ON FEBRUARY 17, 2006. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
NOTES:
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
RECALL Subject : BIG DOG/KICKSTAND SPRING STUD FRACTURE
Report Receipt Date: NOV 02, 2004
NHTSA Campaign Number: 04V523000
8 Associated Documents
SUMMARY:
ON CERTAIN MOTORCYCLES, THE KICKSTAND SPRING ATTACHING STUD MAY BREAK OFF ALLOWING THE KICKSTAND TO DEPLOY INTO THE EXTENDED POSITION.
CONSEQUENCE:
IF THE KICKSTAND DEPLOYS, IT COULD CAUSE A CRASH WITHOUT PRIOR WARNING.
REMEDY:
DEALERS WILL INSPECT AND INSTALL A NEW KICKSTAND UNIT. THE RECALL BEGAN ON DECEMBER 20, 2004. OWNERS SHOULD CONTACT BIG DOG AT 316-267-9121.
NOTES:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
RECALL Subject : BIG DOG/HANDLEBAR
Report Receipt Date: APR 06, 2004
NHTSA Campaign Number: 04V164000
Component(s): STEERING
10 Associated Documents
SUMMARY:
ON CERTAIN MOTORCYCLES, A SCREW MAY BECOME LOOSE IN THE HANDLEBAR CONTROL DUE TO THE LACK OF A LOCK WASHER AND LOCTITE.
CONSEQUENCE:
THIS COULD CAUSE THE THROTTLE OR FRONT BRAKE CONTROL TO BIND, WHICH COULD RESULT IN A CRASH.
REMEDY:
DEALERS WILL INSTALL A LOCK WASHER AND LOCTITE. OWNER NOTIFICATION BEGAN ON APRIL 12, 2004. OWNERS SHOULD CONTACT BIG DOG AT 1-316-219-7006.
NOTES:
RECALL Subject : BIG DOG/REAR MASTER CYLINDER PISTON
Report Receipt Date: MAR 23, 2004
NHTSA Campaign Number: 04V137000
Component(s): SERVICE BRAKES, HYDRAULIC
SUMMARY:
ON CERTAIN MOTORCYCLES, THE PISTON IN THE REAR MASTER CYLINDER MAY HAVE BEEN IMPROPERLY SIZED, WHICH COULD CAUSE THE REAR BRAKES TO DRAG OR LOCKUP.
CONSEQUENCE:
THIS COULD RESULT IN A CRASH.
REMEDY:
DEALERS WILL REMOVE THE PISTON FROM THE REAR MASTER CYLINDER AND REPLACE IT WITH A NEW PISTON. OWNER NOTIFICATION BEGAN ON APRIL 12, 2004. OWNERS SHOULD CONTACT BIG DOG AT 1-316-267-9121.
NOTES:
RECALL Subject : BIG DOG/FRAME CRACKS
Report Receipt Date: DEC 18, 2003
NHTSA Campaign Number: 03V535000
Vehicle MakeModelModel Year(s)
BIGDOGCHOPPER2003-2004
12 Associated Documents
SUMMARY:
ON CERTAIN MOTORCYCLES ASSEMBLED WITH AN EARLY VERSION ROLLING THUNDER FRAME, A STRESS CRACK COULD EMERGE IN THE FRAME.
CONSEQUENCE:
THIS CONDITION COULD OCCUR WITHOUT ANY PRIOR WARNING, INCREASING THE RISK OF A CRASH.
REMEDY:
DEALERS WILL REPAIR THE FRAME. OWNER NOTIFICATION BEGAN JANUARY 15, 2004. OWNERS SHOULD CONTACT BIG DOG AT 1-316-267-9121.
NOTES:
Name Description Size(KB)
RCDNN-03V535-1228.pdf Defect and Noncompliance Notice(Part 573) 25
RCFK-03V535-2658.pdf Fax Acknowledgement 17
RCMN-03V535-7761.pdf Manufacturer Notices(to Dealers,etc) 50
RCONL-03V535-2321.pdf Owner Notification Letter(Part 577) 22
RCQPR-03V535-3755.PDF Quarterly Performance Report 31
RCQPR-03V535-5478.PDF Quarterly Performance Report 28
RCQPR-03V535-6999.pdf Quarterly Performance Report 13
RCQPR-03V535-7465.pdf Quarterly Performance Report 13
RCQPR-03V535-9753.PDF Quarterly Performance Report
