All good suggestions but I have 2 jacks. The problem is that there are three spacers -- a wide one on the left side, and a medium-width one plus a thin (1/8") one on the right side. The axle on the right side also has to go thru the caliper bracket.
Axle enters on the left side - no problem getting it thru the wide spacer and the wheel. On the right side, there is the medium spacer, then the bracket, then the thin spacer. Everything works fine until I try to put the thin spacer between the bracket and the swingarm. It came off easily but now it seems like there's not enough room to put in back in.
I've reseated the races/bearings thinking that they may have moved but that's not the problem. I scratched up my billet brake bracket trying to put this thing back together. Got that all polished out but still can't figure out why that thin spacer doesn't have enough room. I know that the whole assembly has to be loose enough to move horizontally to get it adjusted properly. I just can't get that #%*&! thin spacer in there.
Been playing with this thing for over a week and I'm unbelievably frustrated at this point because I'm a passable mechanic. Any genius' out there who may have had the same problem and found a fix?
