Aloha All...
My boss's bike is a 2004. Not sure on the model, but it has long forks. The rear tire is a 250.
Went to fill air in the rear tire, and found the valve stem loose. Took a wrench to the nut and tried to tighten the nut down. Didn't take much effort, and just when I was about to stop, the nut slipped on the valve stem - like the tread on either the nut or valve stem is stripped - chet! Tried again with the wrench, but I alreay knew what the outcome was gonna be.
Still not sure which tread stripped - the nut or valve stem. The valve stem is treaded all the way with the same tread as the valve stem cap. A guy at a fastener speciality store told me it's pipe tread.
Here's a dumb question - I'm not sure if the tire bead can be broken from the wheel with the tire/rim still mounted on the bike. If it's possible, may be able to replace the valve stem without removing the wheel...
If it's the nut that's stripped, I'd still need to locate the nut.
Anyone have any suggestion?
Hope to hear from you all soon...
Thanking you all in advance!
Localboy...
Localboy...
