Rear Teflon Pulley resolves Belt Chirp
Fat_Bastard
Belt Chirp with stock non-Teflon pulley was solved with Fuchs ProPrep Silkoline spray every few rides. However this was a nuisance...
My old buddy "Raywood" a few years back said I should get one of those stock newer Teflon coated pulleys and that would work too. Had occasion to get a stock Big Dog Mad Clown Pulley Teflon Coated. Yes, it is on and solved the Chirp problem with no belt dressing. As you can see in the photo after about 300 miles the beautiful Teflon coating seems to be quickly wearing off... This coating appears to be like that on a cheap frying pan! Will see how long it lasts...
Original stock pulley off the wheel; 2004 Big Dog Chopper
new Teflon pulley on the wheel
lentzii
Hy, Riemenspannung? ? ? Faustregel! ! ! Bedenken oben in der Mitte mit 2 Finger (Daumen und Zeigefinger) um 90 Grad zum drehen möglichen Sein. Rad läuft gerade ? ? ? Gruß Lentzi.
Fat_Bastard
Hallo deutscher Freund Lentzi, Die Gürtelspannung ist richtig. Die Riemenscheiben sind mit einem Laser... Nur zu sagen, die Teflon-Beschichtung ist von billiger Qualität. Aber kein Chirp!:)
