Rear Pulley Screw Size
Scottie
If you disassemble the rear pulley, there are several flat top screws that hold one side of the pulley together. Does anybody know the size/type of those screws? The pulley is off a 2007 K9. Thanks
z4racer
Best way to find out is to go over to BDM performance website, select bigdog parts. Then select exploded view. This will give model selections and then schematic views of all parts and bolts. The bolt description will provide all the detail you need.
z4racer
Brew, that is the exact picture on BDM performance website. It does not show the bolt on the pulley that go from inside to outside. I looked on my K-9 and there are bolt there.
DRBarnhart
Insert title here...
I also have a '07 K-9 and there's no bolts going from the "inside to the outside" through the pulley. My back wheel is just like the pic that Brew posted.
Is your wheel and/or pulley stock? :confused:
Dennis
Scottie
Yes it is stock :) Optional but stock from BDM.
There are several flat head screws on the pulley trim ring.
z4racer
Mine is like Scottie's, in that it has the bolts on the back side of the rear pulley. Hopefully a picture is attached. And DAMN now I have to go clean the back of my pulley.
Brew
Take that screw down to ACE, Home Depot or Lowes hardware stores and compare it to what they have in the custom bolts section. They may have what you need! I buy lots of replacement hardware from these stores...
z4racer
ACE is the place for all your nutz and boltz.
