Rear cylinder not firing
Keith S
EHC FREE!!!!
Hi everyone -
I need some help trouble shooting an issue.
'04' Chopper DT
S&S 107
Crane Hi-4 ignition (8-4100)
Wire Plus EHC elimination harness (one of the first ones)
The rear cylinder is not firing. I checked the coil and am getting 3.5 Ohms on both sides. I switch plugs and put front to back / back to front and it won't fire, but did backfire.
Consensus is bad coil, but I wanted to check other possibilities before I started throwing parts at it.
Any ideas are appreciated.
Keith
Keith S
EHC FREE!!!!
HHmmmm...it is now. I took the coil completely off to make sure I ordered the right one. I put it back on to check the spark and it ran perfectly. I did not see any corrosion or loose wires, but I am guessing that was it.
