Really again
BOOGYMAN1323
well i replaced my battery the other day due to it being dead so new battery in and i fire her she starts right up let it idle for about 5 mins everythings good i goto take of it backfires and shuts down i try to start and just keeps turning over so i wait alittle while and she fires back up again i goto tke off and nothing back fires and shuts down now new battery is dead is this due to VR or stator if so where can i get both of them thank you all
BigDogBro1
Made in the USA
Fully recharge the battery and measure volts at terminals after disconnected from the charger for an hour. What's the battery voltage while parked?
Should get near 14 volts across battery with volt meter while running around 2000 RPM.
1BADK9
Limited Edition Member
Whoa there Bobby.... don't go buying two things when it may only be one or none. Check the obvious first, good tight connections everywhere and nothing rattled loose? Then look under the techinal threads and verfiy if your voltage regualtor is functioning properly. Easy checks with a voltmeter.
Here's a couple of threads to get you started.
http://www.bigdogbiker.com/forums/technical/17172-starter-system.html
http://www.bigdogbiker.com/forums/how/24664-stator-check-out.html
Let us know what you find. Good luck :2thumbs:
BOOGYMAN1323
ok guys thank you very much i went and charged the battery and tested everything all checks out but now here is the thing i pull the enricher up and start her then when i push the enricher down she shuts out but as long as i have the enricher just alittle open it will stay running but like i said as soon as i turn the enricher off the bike dog goes off am i doing something wrong or is my dog wrong
jm96732
how long has the bike been sitting? sounds like the idle curcuit (jet or passage) could be plugged. this is a common problem with bikes that was stored with fuel still in carb. remove fuel bowl from carb and clean the jets and passages. hope this helps
BadBrad
2005 Pitbull
You can get seafoam at any car parts store. It's just a good all around system cleaner that stabilizes your fuel and cleans internal carb parts that it comes in contact with.
