Rattle Noise.... where it comes from????
francoblay1
The Spaniard
Alright guys (sorry for the waiting, had to go to pick up Julia from School) ... oh, and no "Siesta" today!!! brrrrrrrrr.
:oldsmile:
And the Winners are..... @BWG56 & @cdogg556 !!!!
What about the baffels in the pipes?
Have you checked to see that the welds are good? Maybe one is cracked and rattling around in the pipe?
I stuck a broom-stick into the pipes and sure enough.... on the front cylinder´s exhaust, if I applied pressure with the stick against the BCT baffle the noise stopped...
As John mentioned, one of (the two) spot welds is broken!!!!! I am lucky I didn't loose the Baffle on the road.
Once fixed I am thinking on placing a bolt on the spot where the original V&H baffles were installed so if the welds brake I wil not loose the baffles.... or re-install the half way cut V&H baffles behind the BCTs... thinking about that one, will see.
OK.... that was the whole Drama!!!!! :chopper:
:whoop:
