QUENCH, SQUISH, and DECK HEIGHT
john sachs
There seems to be some confusion on the meaning of quench and squish. I'll try to explain, in simple terms, the meaning.
Quench and squish are the same thing: the distance of the piston from the deck of the head, including the head gasket, or the radius piston dome(hemi style) from the radius of the combustion chamber(hemi style).
There are ONLY several ways to correct problems in this area.
1- Custom pistons with a taller crown.
2- Machine down cylinders that are too tall.
3- Spin drop the heads.
4- Thinner or no base gaskets. (small corrections).
You can mill the heads to death, and that will NOT tighten up the quench.
The EPA 117" S&S engines have a .040" taller cylinder. Changing head gaskets, milling the shit out of the heads, or using a .010" base gasket, or no base gasket will never deliever the proper quench on one of these engines.
Ideal quench/squish is between .030" and .040"........... meaning -0- deck, and between a .030" and .040" head gasket.
Deck height is the distance of the piston crown to the top of the cylinder. Ideal is piston even with top of cylinder.
The EPA 124" S&S engines have approx. .090" taller cylinders. The ONLY way to fix this nightmare is to cut the cylinders down.
Singh grooves are supposed to help curb detonation, and help tuning.... I've grooved several sets of heads and found nothing different (on the dyno or on the road).
Hope this helps. :eek:
John
MARV
Cut .040 off the jugs and .060 off the heads about 5 years ago. With the 640 cam, a bit of clearance on the tappet blocks, limiters, jims rollers and 640 springs. 2ki ignition and psi carb. A bit of clay to be sure i had clearance. She really rolled nice. Freshen up is in order soon.
Always a pleasure to hear from you john
Save to How To section
Thanks John
Sent from my DROID RAZR using Tapatalk 2
francoblay1
The Spaniard
John, let me know when your next visit to Spain will be. :D
Accommodation, food & beer will be free for you :2thumbs:
