Pushrod adjustment - bleeding hydros
MARV
Oh no, V,
All pushrods are adjusted. The one that I'm not 100% sure on, too. This one I want to do again with correct oil pressure in the hydraulic tappet. After doing this pushrod and beeding down the hydraulic lifter, I could turn it by hand. So this should be ok for running the engine with the starter only.
Are you sure, you get oil pressure by turning the wheel by hand :confused:?
Brew,
my bike has only 1500 miles on it.
Jochen
You don't need them to be full as the spring keeps the piston of the lifter extended.
Just be sure that valve is closed, loosen the rod to zero lash, tighten the appropriate turns to get to 1/2 piston travel, lock it, let it bleed, check that the rod will spin
