puke can question?
03pitdog
Hey guys. I got a 2003 107 im going to run a puke can can i ty both head breather hoses together and run one hose from heads and the crankcase vent hose to the same puke can with air filter on can? thanks
Sure. Many old threads here on this. I've posted many pics of custom bikes running the two lines to a miniature Jack or Beam bottle
Sent from my DROID RAZR using Tapatalk 2
03pitdog
thanks saw other threads but didnt see anyone run both heads and the crankcase vent into one puke can didnt know if it would cause issues
03pitdog
Called s&s and they said this could be done with no problems. I had ran a hose from front breather bolt to rear breather bolt and a hose from rear breather bolt to puke can but was still getting a little blow by from crankcase vent which also attatched to backing plate. So ran crankcase vent also to the same puke can with a filter on top and now blow by from any of the three can only go in can. Just thought i would enlighten on what i did and that s&s said this would work fine. I have the older 107 breather system with breather bolts for venting the heads.
