PSI CARBS ARE THE SHIT!!!!
pisssed
pisssed
OUCH, pissed sounds pissed!
I'm not second guessing, but the bottom run indicates an additional 20 hp or an 18% gain, and an additional 8 ft lbs or 10% gain. Pretty strong for nothing more than a bolt on carb. But then again, the PSI site say's up to 22 hp!? These carbs just may be the shit.
Not pissed at all, but if You make a statment as listed above You better back it. I have no problem calling someone out. Its all good dont take offence scott
ps I hope all the above is true I want the PSI myself:up:
Scott041804
Well whatever the temperture was it was all dont within the same two hours, as in running it with the G and then swaping it out and running it with the PSI. These sheets are not modified or bullshit. This is the real deal!!!!!
Scott041804
I will guarantee a 10 % increse on these carb!! I am not here to BS anyone. We have the equiptment here that proves these out!!!! We here at Gateway Big Dog St. Louis are know for performance, and i am just here to help everyone out and tell you whats good and bad. We do alot of performance on bikes and we know what is good and what is bad. I will not lie to you to get you to buy something.
05chop
Scott Post some pic of your bike!!!!!!!!!!! Does your bike have chain drive with all that hp? 05chop
Scott041804
I will post my bike on here, its all apart because I blew out the transmission. But i will post them. Its a 2003 Big dog pitbull all modified. 117 s and s transmission
Scott041804
Well i broke one belt last summer. I put another one on it. I will eventually put a chain on it when i break another belt. You can see my photo. I can stand that bike up through 3rd gear on the back wheel shifting.
go4dave
Hey SCOTT, I'd like to have that kinda' horsepower. :up: Take a look at these 2 sites i've listed.
Corrected Power
Relative Horsepower Calculator
Just to let you know,, i'm a NUMBERS junkie :2thumbs: ,, the world of hanging shit over the ROCK stars head, :bang: , turns me into a human calculator. So,, i dig playing with numbers. :whoop:
When you do your dyno runs.... document these things:
TEMP
BAROMETRIC PRESSURE for the run
HUMIDITY for the run
ELEVATION this is a constant, unless you're a moble dyno unit.
All of these effect dyno readings. All this info,, should be ON or IN the software on your dyno.
Anyway, you are a lucky DOG. :D Here is Las Vegas,, right now,, today 12/8,, the same bike would build only 93.7% of it's horsepower :down:
Today in ST. LOUIS your bike will show 106.8% of it's actual horsepower :up: Based on the conditions in each place.
Air Density makes a HUGE difference in Horsepower. Check out those sites,,, hopefully, you'll get something out of them.
Are you talking about your avatar? If so lets see the full sized pic!!!
Black Dawg
Pretty bold claims but after doing some research I think it's entirely possible. $1095 + $100 if you want it chromed.
Scott041804
Corrected Power
TEMP
Yes our program does tell us all that stuff. I will have to go over there and check it all out. I will have to pull the sheets and look into the options and it will tell me temp and bar pressure. I will try to do it at the beg of the week for you
