Problem with low beam
nobbyjohn
High beam is fine just low beam keeps blowing out . Was wondering if i could possible have an electrical problem or could i be so lucky as to only need an anti vibration bulb. I do have the wire plus in my K9 any ideas would be welcome!
firedog19
The low beam on my 04 ridgeback does the same thing. It is a pin on the ehc plug. If I wiggle it back and forth it will come on. Right now I have a piece of rubber pushing forward on the plug wedged between the battery and the plug. Waiting for wow to get their replacement control module in production
BigDogBro1
Made in the USA
Which bike of yours are you having the problem?
Could be vibration.
Voltage spikes or a higher than normal 14v continuous charging voltage, I would expect to burn out more than just the low beam filament.
