f-okie
AllGaveSome-SomeGaveAll
I need abit of help on this one. On my 06 K-9, I changed to Bakers Open Primary a few years back and had no problems until now. I turned the front pulley seal over for the open primary as required. After about 15,000 miles, the front seal started to leak. The funny thing is, it leaks after the bike has set for several days in the garage. I've replaced the seal 3 times, and it works ok until I get about 150 miles on it. I've noticed it seems to leak more when it has been sitting several days in a hot garage, almost like it's building up some kind of pressure in the engine. It might be a two or three drop, or a football sized leak. I've checked the pulley surface for marks, but it appears to be ok. I sure hope someone can help...
Thanks
Thanks
