chopsteak
Well, as you may know I recently rebuilt the trans with success. I now have an inner primary leak again. THis leak is what originally led to me finding the "play" in the input shaft. Baker said I could get an O ring from Harley #11147. This O ring fits between the engine and the inner primary cover. WHen I rebuilt the primary and trans I replaced this gasket with a new one and it's still leaking. Everything torqued up right in the coorect pattern. Took it all apart last night and couldn't find a kink or a bad spot on the ring. Gonna try a small bead of high temp rtv this time with the O ring.
